1993 Oldsmobile Cutlass Idle air valve
CONCERNED890
  • 7 POSTS
Engine Mechanical problem
1993 Oldsmobile Cutlass 6 cyl Automatic
Could someone please tell me the exact things that ocur when you have a bad idle air control valve, a bad mass sensor and throttle sensor. I had the mass sensor replaced but my car still quits after i drive it for awhile but it will soon crank and run again. At night or when it cool it doesn't seem to be a problem.
Jun 25, 2008 at 3:38 PM
BLACKOP555
  • 10,386 POSTS
i can explain them to you.
or you can post back and tell me what is happening, when and what youve replaced and i can help you figure it out. by the way none of your options that you listed woudl cause your problem from what i read in y our post.
Jun 26, 2008 at 1:24 AM
CONCERNED890
  • 7 POSTS
Okay when I drive my car for a short period of time it will quit. If I come to a complete stop it will shut up but cranks right back. When i put it in gear it shuts off again but after about 4 tries it will soon crank again and when i drive and come to another stop it does the same thing. Sometimes when i restart the car it will isle up real high then go back down. After the mass sensor was replaced i noticed it was still missing a little bit when i drive but that wasn't the problem cause it's still shutting off.
Jun 26, 2008 at 12:06 PM
BLACKOP555
  • 10,386 POSTS
the vehicle doesnt always rev up when the vehicle is started?
it should only rev up about 1000 rpms at the most.
could have a bad IAC module, with it disconnected run the vehicle. does it still die?
Jun 26, 2008 at 3:26 PM
