1993 Oldsmobile Cutlass how to adjust idle on my 3.4l v6 cu
120,000 MILES • 6 CYL • FWD • AUTOMATIC
MYOUNG4
  • 6 POSTS
how to adjust idle on my 3.4l v6 cutlass supreme.
I have replaced the idle air valve and the tps and the idle is still erratic
Mar 14, 2010 at 4:21 AM
LEGITIMATE007
  • 5,121 POSTS
you cannot adjust the idle, if the idle is erratic and you've changed the IAC, then the problem lies somewhere else, clean the throttle body, change pcv and check fuel pressure and fuel filter
Mar 18, 2010 at 12:50 PM
LEGITIMATE007
  • 5,121 POSTS
