1993 Oldsmobile Cutlass Fuel Pump
RTKEEFE
1993 Oldsmobile Cutlass Front Wheel Drive Automatic 80,000 miles
Where is the fuel pump located and how do I relace it.
May 11, 2009 at 10:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
What size engine is equipped? Is this a Cutlass Cierra, Cruiser, or Supreme ?
May 11, 2009 at 11:12 AM
RTKEEFE
Its is a Cutless Ciera, 3300 V6
May 11, 2009 at 12:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel pump is located inside of the fuel tank.
REMOVAL:
Disconnect negative battery cable. Relieve the fuel pressure. Remove the filler neck then lower the fuel tank. Disconnect fuel lines and electrical connections.
Remove fuel level sending unit and fuel pump retaining bolts or cam locking ring. Lift assembly from fuel tank and remove the fuel pump from the sending unit.
Pull fuel pump upward while pulling away from bottom support. Use care not to damage rubber insulator and strainer.
INSTALLATION:
To install, reverse removal procedures using a NEW "O" ring/gasket. Tighten fasteners to proper specifications.
Thanks for using 2CarPros.com!
May 11, 2009 at 12:59 PM
