1993 Oldsmobile Cutlass courtesy lights stay on
1993 OLDSMOBILE CUTLASS
101,423 MILES • 6 CYL • FWD • AUTOMATIC
GREG2080
The courtesy lights(dome, rear view mirror) stay on after the driver's door handle is used but don't go off after the 40 seconds. I can't find a relay for the switch so can't tell if its that or the switch in the door handle itself. Haynes book no help.
Aug 1, 2008 at 10:53 AM
MASTERTECHTIM
  • 4,750 POSTS
i have had a number of them being bad switches at the latch. try spraying the beegeezus out of the latch while opening and shutting the door. use wd40 or any light penetrating oil, no grease
Aug 2, 2008 at 11:18 PM
