1993 Oldsmobile Cutlass
1993 OLDSMOBILE CUTLASS
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADAMJMAC
While driving the car dies and wont restart, ive replaced the fuel filter, spark plugs and wires, ive also tested the coil packs and ignition module all tested good, what else can cause this???
Aug 26, 2009 at 6:32 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
When this happens and it doesn't start, have you checked to see if the engine is getting spark and fuel? Also, have you checked fuel pump pressure and has the check engine light come on?
Sep 18, 2009 at 10:28 AM
