Ignition module replacement?
1993 OLDSMOBILE CUTLASS
JEFF LOWELL
does an ignition module have to be type specific? will a 3.8 engine module work on a 3.3 engine?
Jul 6, 2009 at 11:11 AM
BUDDYCRAIGG
  • 2,262 POSTS
Here is the ignition module which is under the coil pack. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jul 6, 2009 at 2:46 PM
JEFF LOWELL
will an ignition module from any g.m. 3.8 liter engine work in my 3.3 liter engine,or does it have to be from a g.m. 3.3?
Jul 7, 2009 at 6:14 AM
BUDDYCRAIGG
  • 2,262 POSTS
No.
even some 3.3 are different in differed cars/vans.
if you a particular car to car, i would look them up for you to see if they match.
Jul 7, 2009 at 10:38 AM
XHEQU
Engine Performance problem
1990 Oldsmobile Cutlass 4 cyl Front Wheel Drive Automatic
90 2.3L calais 2 and 3 cylinders missfire (wet).Change plugs,coils,ignition module,housing,computer etc. 2 and 3 still miss. Compressures and fuel injections are ok. Anyone has a idea?
Thanks!
Jul 28, 2020 at 7:37 AM (Merged)
  • 110,244 POSTS
Does it miss when it's dry? Did you replace the plug wires?
JUMPERFREE
Engine Mechanical problem
1989 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
where is the ignition module located and how do I test if it works o.k.
INTERNETMECHANIC
  • 700 POSTS
Olds cutlass what? My database shows several cutlass. If dis ignition, it is under the coil pack. If you have a distributor, it is in the distributor. Any applicable trouble codes? I need more information? Exactly what is the problem?
