1993 Oldsmobile Cutlass
JRHAMLIN
  • 1993 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 149,000 MILES
Im having problems when I go to take off my car wants to die out and I have to restart it. I know it may be a cencer but I dont know what one it would be. It also wants to idle up when I start it up
Wednesday, February 24th, 2010 AT 4:40 PM
HMAC300
  • 48,601 POSTS
You will have to pull the codes to see if there are any sensors that are screwing up first to see why the car is dieing. Then you might try king some choke cleaner and cleaning the throttle plate on both sides. Then put the air duct back on, Then change the fuel filter and start the car. It may be a little hard to start at first after using the choke cleaner.
Saturday, February 27th, 2010 AT 12:25 PM
