My cooling fan won't come on. I let the car run with the air condition and/or heater turned on at full range. The temp reaches 220 degree, but, the fan won't come on. I checked all fuese, every one is ok. I checked whatever relay I could find in front of the engine, inclduing the relay for the heater. All relays are ok. For some reason I am not able to find the relay for the fan. I found about 5 relays in front. I shorted the cotact (A to E) for each relay. Everytime something turns on which is not the fan. I have replaced the thermostat. I verified it works, becuase both the engine side and the radiator side of the top hose get realy hot when touched. The radiator also feels realy hot, but for some reason the fan won't turn on. Where is the relay for the fan located so that I can test it to see if my electric fan works.
Thank you very much for your help.
Dec 1, 2008 at 10:54 AM
