1992 Oldsmobile Cutlass Thermostat
1992 OLDSMOBILE CUTLASS
203,000 MILES • 6 CYL • FWD • AUTOMATIC
TAZMANSGIRL
I need to find out how to replace the thermostat on my 1992 Oldsmobile Cutlass Cierra. I know that it is at the engine end of the top radiator hose but I need to find it from there. I am stuck.
Jan 2, 2009 at 8:15 AM
  • 110,244 POSTS
Hi:
At the end of the upper hose it attaches to the thermostat housing. Drain the coolant from the radiator, unclamp the hose from the housing, unbolt the thermostat, and the t-stat is under it. Just reverse the sequence to replace it. NOTE: Pay attention to the direction the t-stat in installed before removing the old one.
If you have other questions, let me know.
Jan 4, 2009 at 12:00 PM
