1992 Oldsmobile Cutlass oil pressure
1992 OLDSMOBILE CUTLASS
160,000 MILES • 6 CYL • FWD • AUTOMATIC
SUELEE46
When I start my car in the morning, the oil pressure is fine. After I drive for about an hour, the pressure drops to below half on the gauge. Lately the pressure is dropping to zero when I come to a complete stop. Do I need a new oil pump?
Jan 13, 2008 at 2:12 AM
MERLIN2021
  • 17,250 POSTS
Could be worn engine parts, too much clearance between bearing inserts and crank...try using a heavier oil blend, say 20-50 or straight 30 non detergent.
Jan 13, 2008 at 2:24 AM
