1992 Oldsmobile Cutlass main crank pulley
120,000 MILES • 6 CYL • FWD • AUTOMATIC
JPHELPS
you do i take off the old pulley without it spinning?
Aug 20, 2009 at 2:58 PM
  • 75,988 POSTS
You need a vibration damper puller-you can rent this out from a tool rental place or use the old method correct size socket with a breaker bar locked in place and crank engine over-be careful doing this take extra caution nobody up front
Aug 20, 2009 at 4:38 PM
