1992 Oldsmobile Cutlass LOCATION OF FUSE BLOCKS
123,000 MILES • 6 CYL • FWD • AUTOMATIC
BARTON1204
I CAN'T FIND THE FUSE BLOCK THAT CONTROLS THE ACCESSORIES. THE OWNERS MANUAL SAYS THAT THERE IS A FUSE BLOCK UNDER THE INSTRUMENT PANEL, BUT I CAN'T FIND IT. NONE OF THE CONTROLS FOR THE CRUISE, HORN, RADIO, AND CLIMATE CONTROL LOCATED ON MY STEERING WHEEL DO NOT WORK. I HAVE FOUND THREE FUSE BLOCKS - ONE IN THE GLOVE BOX, AND TWO IN THE ENGINE COMPARTMENT, BUT THERE IS SUPPOSED TO BE ANOTHER ONE UNDER THE INSTRUMENT PANEL. PLEASE HELP ME AS I CAN'T FIND IT.
Mar 12, 2008 at 4:58 AM
LEGITIMATE007
  • 5,121 POSTS
you should be able to unscrew the panel right under your steering wheel to reveal the other fuses
Mar 25, 2008 at 6:12 AM
