1992 Oldsmobile Cutlass help.......
BOB100
Heater problem
1992 Oldsmobile Cutlass 4 cyl Two Wheel Drive Automatic
hello there,having trouble with cold air blowing,no hot air,have changed thermosat still blowing cold checked the old thermosstat and it popped when it was put in hot water.am now fushing system,if it is not the thermostat what do i do next.....
Oct 18, 2010 at 6:09 AM
JDL
  • 16,098 POSTS
When the engine reaches operating temp, are the heater hoses hot? Another issue could be directional doors under the dash that aren't opening or closing like they should? Can you direct the air anywhere you want, defrost--floor-- dash?
Oct 18, 2010 at 6:24 AM
