1992 Oldsmobile Cutlass Car horn
1992 OLDSMOBILE CUTLASS
MS.ISIS
The horn in my car wont work i have checked the fuses and everything seems ok there but cannot figure out whats wrong with the horn or where its located so i can fix it
Nov 18, 2009 at 4:53 PM
JDL
  • 16,098 POSTS
welcome to the forum, which cutlass? The horns should be under the hood, front, right and left side. Horn relay, underhood, driver side, electrical center. The problem is usually the wiring circuits in steering column. The horn button is a ground for the horn relay. If you work around the steering column, disarm airbag where applicable. The info I looked at was a cutlass supreme. Also, check horn fuse-- 15 amp, not only check fuse, use a testlite, see if the fuse circuit is hot?
Nov 19, 2009 at 9:52 AM
