Hello, did the problem start after you had the work done? You might talk to the people that did the work. Do all the speeds work correctly? Do the directional controls work for floor-- defrost--panel? You may need to check the actuators, make sure those doors are working as they should.
SPONSORED LINKS
Tuesday, August 11th, 2009 AT 9:10 AM
