1992 Oldsmobile Cutlass 1992 Cutlass cierra dies randomly
ROBINMOIX
1992 Oldsmobile Cutlass 6 cyl Automatic 103000 miles
My car will just die randomly. I can usually restart but sometimes have to try a couple of times. It does this at stop signs and while driving down the road with no warning. All the dashboard lights come on and it quits moving. I have had it in the shop 4 times. The first time I was driving in a round-about. The mechanic said I needed a cooling fan. Then a couple weeks go by and it happened again driving down a busy road. This time I had gunk on some stuff. Then a couple more weeks go by and it did it at a stop sign. The mechanic had it for a week and it never would mess up on him. So I get it back and it does it again driving down the road. This time I took it to a dealership. Of course it did not mess up on them during the week they had it . Now I have had it back for 3 weeks and it did it today at a stop sign. I really do not know what to do . Please help.
Jul 20, 2009 at 8:08 AM
  • 110,248 POSTS
Has the check engine light come on? Have they checked for vacuum leaks, fuel pressure, and the catylatic converter?
Aug 9, 2009 at 5:08 PM
ROBINMOIX
They claimed they have checked everything. This past week they said it was an ignition module. They changed it. I drove it about a mile before it stopped again. They have it again now, checking to see if the new part is faulty. Everytime I suggest something, they say they have checked it. I have not mentioned Vacuum leaks though, so I will. Thanks for the response.--Robin
Aug 9, 2009 at 5:49 PM
  • 110,248 POSTS
Robin:
WHen it dies, if you cycle the key from off to on, can you hear the fuel pump working?
Aug 10, 2009 at 12:41 PM
ROBINMOIX
Since I am usually in the middle of the traffic when it occurs. I quickly put it in neutral amd it immediately turns over. One of the last times it hapened, it kind of jerked forward a couple of times and acted like it might die again. Then it regained normal behavior. I am sorry I never listened to see if the fuel pump was working, I was always too afraid someone was going to run into me.
Thank you,
Robin
Aug 10, 2009 at 3:39 PM
  • 110,248 POSTS
Robin:
It's hard for me to tell. If I had to guess, I would say it is a bad ignition module, but they told you it was fine.
Aug 10, 2009 at 3:49 PM
ROBINMOIX
Actually that is what they said, but it still happened after they replaced it. I asked them if the replacement could be faulty, to which I received an eye roll. I know that some times even a new part can be bad. They said they would check it to see. Thank you so much for your advice and help.
Robin
Aug 10, 2009 at 6:26 PM
GLORYCARRIER
I am very interested to find out if you have figured it out yet. I have a 94 Olds Cutlass Supreme that is doing the same thing. Also occasionally it won't start. It clicks once and if I wait and try later it will usually start. My mechanic says the 2 aren't related. He replaced the starter already, but that wasn't it.
The stalling seems to be worse when the weather is hot...My mechanic is very honest and has been working on this for 3 months. He has replaced the cam shaft sensor, relays, etc. He has a hard time getting it to do it for him. Some days there is no problem and other days I have to limp back to the shop. So frustrating!
Aug 11, 2009 at 4:45 AM
  • 110,248 POSTS
Robin:
I agree. I have seen new parts that were bad many times.
Aug 11, 2009 at 6:40 AM
