1991 Oldsmobile Cutlass Engine stalls when slowing down
150,000 MILES • 6 CYL • FWD • AUTOMATIC
RUSTYRAT
91 Olds Cutlass Supreme (3.1 L, 6 cyl.) stalls when slowing down. Will not restart until after some amount of time like overnight.
Apr 16, 2010 at 7:09 AM
  • 75,988 POSTS
Next time it will not start do below to find out if its a fuel or spark problem don't wait for nothing
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Apr 16, 2010 at 7:17 AM
