1991 Oldsmobile Cutlass Car shakes at highway speeds
GOLF_STUD9
Shakes or Wobbles problem
1991 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
My oldsmobile just started shaking while going down the highway. At speeds under 50 everything is fine. at speeds over 60 the whole font end starts to shake. The sterring wheel even shakes violently. Could this be the front end needs to be rebalanced or is something else wrong.
Dec 16, 2009 at 12:58 AM
HMAC300
  • 48,601 POSTS
have your tires checked for balance or wear. aloto of times a bad tire will cause this. You can look for bulging on the tires, if this is the case get it to the tire store immediately as it may burst while driving. Also have them check your front end parts for wear. they shouldn't charge for the front end inspection.
Dec 20, 2009 at 12:02 PM
