1991 Oldsmobile Cutlass Bad Pulley
68,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHEZFROSTY
I seem to have a bad pulley on my water pump and the car is overheating, there also seems to be oil mixed in with the coolant. I recently had the alternator, the power steering pump, and the serpentine belt replaced. Wouldn't a bad pulley have been noted by the mechanic at that time? Or would something else cause the pulley to go bad out of nowhere?
Mar 31, 2010 at 2:32 PM
  • 110,248 POSTS
If oil is in the coolant, then you have a head gasket leaking. As far as the waterpump pulley, they don't go bad. If there is play in it, the bearing in the pump is bad.
May 19, 2010 at 3:38 AM
