1990 Oldsmobile Cutlass Rear disk brakes
120,000 MILES • 6 CYL • FWD • AUTOMATIC
EWIZZER
right rear brake caliper is not releasing. I just replaced it with a new one and bleed the system. the left side is working fine I replaced it too. It is not releasing the pressure in the caliper.
Jul 8, 2008 at 5:14 AM
DOCFIXIT
  • 18,828 POSTS
Open bleeder does it release pressure and free rotor? If yes replace the flexible brake line it has ruptured inside and is holding pressure.
Hope this helps
Jul 8, 2008 at 5:53 AM
