Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Cutlass
Brakes
Rotor
Replace/Remove
1990 Oldsmobile Cutlass Rear Disc Brake Replacement
1990 OLDSMOBILE CUTLASS
87,000 MILES • 6 CYL • FWD • AUTOMATIC
ABROMC454JIVE
MEMBER
1 POST
How difficult is it to replace the rear brake pads and rotors? Is a special too required?
May 22, 2009 at 10:32 AM
Experienced Mechanic
They are easy to replace, and no special tools are needed. Here are directions for you to review. They will show and explain what you need to do.
https://www.2carpros.com/how_to/rear_brake_pads.htm
Let me know if this helps.
May 27, 2009 at 12:13 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
