Hi. My 1990 Oldsmobile Cutlass Ciera has 132,000 miles....the "Service Engine Soon" light comes on at low idle. When the rpm's are increased, the light goes out. I suspect low oil pressure. Will replacing the oil pump help this? I know it's an external pump. (i've already changed the oil and filter) ? Please advise and thank you.
P.S. If you know where I can find a used tail lens for the driver's side, I would greatly appreciate it. Thanks again......Jason--Virginia
Jul 10, 2008 at 3:28 AM
