HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
Cutlass
Engine
Symptoms
Stall While Driving
SPONSORED LINKS
1990 Oldsmobile Cutlass Car idles perfectly, cuts off when
FRED4190
MEMBER
1990 OLDSMOBILE CUTLASS
Engine Performance problem
1990 Oldsmobile Cutlass 6 cyl
We've replaced the module, coil pack, fuel pump, ignition switch, and no dice. Anyone got any idea what the heck is going on?
Thursday, September 2nd, 2010 AT 12:38 PM
MECHANIC
Only part of the heading is readable. When does the engine cut out?
SPONSORED LINKS
Sunday, September 5th, 2010 AT 11:55 PM
FRED4190
MEMBER
It cuts off as soon as the gas is touched. It idles good.
Monday, September 6th, 2010 AT 12:46 PM
MECHANIC
Have the throttle position sensor checked or replaced.
Let me know what you find.
Monday, September 6th, 2010 AT 9:48 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
1990 Oldsmobile Cutlass Engine Quits After Running.
The Engine Will Start Normally, And Run For Some Random Amount Of Time, Then Just Quit - No Stumbling, Chugging, Bucking, Or Anything...
Asked by
eyewonder
1990
OLDSMOBILE CUTLASS
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
1990 Oldsmobile Cutlass Car Stalls While Driving
Hello, This Car Has To Have A New Battery Replaced Every 2 Months. The Alternator Tested Good. I Just Replaced The Battery Last Night...
Asked by
judek
1990
OLDSMOBILE CUTLASS
Car Cuts Off Sometimes
If My 90 Cutlass Supreme Cuts Off Sometimes When Driving Or Idling And Starts Again After About 10 Minutes Sitting And Has A Code In The...
Asked by
myjobrules
1 ANSWER
1990
OLDSMOBILE CUTLASS
1990 Oldsmobile Cutlass Engine Stalls After Warming...
After Driving On The Freeway For 10 Minutes, The First Light I Come To My Engine Will Start Feeling Jumpy So I'll Give It Gas And It Makes...
Asked by
biglee2007
1990
OLDSMOBILE CUTLASS
90 Cutlass Cuts Off When Driving Or Idling & Will...
Checked Codes Found #22 Tbs Sensor Changed Sensor, Cleared Codes Ran Ok For A Day Or 2 But Started To Idle High. Was Idling For About 20...
Asked by
myjobrules
1 ANSWER
1990
OLDSMOBILE CUTLASS
VIEW MORE
SPONSORED LINKS
What to Do When a Check Engine Light?
How to Read Codes
Check Engine Light
Online car repair manuals
