1989 Oldsmobile Cutlass NOT STARTIN
MEATBURGER32
  • 1989 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 192,000 MILES
ONE MY CAR WAS RUNNING FINE THEN OUT OF NOWHERE MY CAR JUST SHUT DOWN I DONT KNOW WAS IT IS
Monday, February 1st, 2010 AT 11:00 AM
JDL
  • 16,098 POSTS
Welcome, Does the starter crank ok? If so, have a helper crank it, while you check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. You can also check your own trouble codes, see if anything shows up?
Monday, February 1st, 2010 AT 11:06 AM
Related Engine Stall While Driving Content
