1989 Oldsmobile Cutlass How Can I Repair Error Codes 22 And
1989 OLDSMOBILE CUTLASS
169,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVE25523
  • 6 POSTS
I Have a 1989 Olds Cutlass with a 3.1 V-6 Motor and it won't run right. I done a scanner on it and it's showing Error Code 22 And 34.
It Says something about low voltage, how can I repair this problem?
Thanks So Much For Your Help.
I need to repair it asap, where I can get back and forth to work.
Thanks
Aug 14, 2009 at 4:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
code 22 indicates a faulty throttle positioin sensor (TPS) or faulty wiring to TPS. code 34 indicates faulty MAP sensor or faulty wiring to sensor.
Aug 14, 2009 at 12:09 PM
STEVE25523
  • 6 POSTS
I purchased a new Map Sensor, but when it's plug up it won't run at all. Someone told me that I had to unhook the battery for a while to reset the computer. Is this something I have to do in order for it to pick up the new MAP?
Thanks
Aug 14, 2009 at 1:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the PCM should automatically detect the new sensor.
what happens when you disconnect the MAP sensor? does the engine idle rougher or stall out completely?
Aug 14, 2009 at 1:34 PM
STEVE25523
  • 6 POSTS
Well when the MAP is unhooked it will start up but won't take gas, but as soon as I hook MAP back up it dies just like I turned the key off.
I put a new MAP on it, but it does the samething.
Do you have any idea how I could fix this?
Thanks So Much For everyones help.
Aug 14, 2009 at 2:21 PM
  • 31,937 POSTS
Hi there,
Have you done a continuity check of the wiring back to the ECU?
Mark, (mhpautos)
Aug 14, 2009 at 8:57 PM
STEVE25523
  • 6 POSTS
No I haven't tried that, what would be the best way to do that?
Thanks
Aug 15, 2009 at 1:25 AM
  • 31,937 POSTS
Do a wire by wire continuity from the sensor to the ECU, you will need the pin code for the ECU and a multi meter with a fine probe to access the pins with out doing any damage.
Mark
Aug 15, 2009 at 2:15 AM
