1989 Oldsmobile Cutlass fuel injector
68,000 MILES • 6 CYL • FWD • AUTOMATIC
BDLEWIS
when I turn on the key, excessive fuel flows into the air intake. flooding it and causing it to backfire. fuel flows continuously into the air intake.
Jul 21, 2010 at 1:46 PM
YOTATECH
  • 5 POSTS
Sounds like an O ring problem. Sounds like the O-ring is broken or missing. Perhaps you could try to get ASE O-rings at a carb shop and replace those carefully.
Aug 5, 2010 at 6:06 AM
YOTATECH
  • 5 POSTS
Afterwards Maybe check the charcoal canister for excessive gas that may have been sucked through. That may need to be replaced.
Aug 5, 2010 at 6:08 AM
