1989 Oldsmobile Cutlass ATF in engine oil
1989 OLDSMOBILE CUTLASS
87,000 MILES • 6 CYL • FWD • AUTOMATIC
KLEIN241
ATF is finding its way into Engine Oil, to the tune of several Quarts. How can this happen. Can smell the ATF in the Oil, and the ATF is low about as much as the Engine Oil is over full.
Jan 26, 2009 at 4:30 AM
  • 110,240 POSTS
are you burning oil?
Jan 26, 2009 at 8:49 AM
KLEIN241
Jan 27, 2009 at 6:53 AM
  • 110,240 POSTS
Hi:
The only thing I can thin of is if the trans has modulator on the side of it that runs on vacuum. If the diaphram goes bad, it could suck ATF into the system that way, but I would think it would burn it. That is why I aske if it was burning oil.
Check for that and let me know what you find.
Jan 27, 2009 at 7:44 AM
