1988 Oldsmobile Cutlass Changing a tire
1988 OLDSMOBILE CUTLASS
LOSDIGGITY
1988 Oldsmobile Cutlass Two Wheel Drive
How do you change a tire for a 1988 Oldmobile Cutlass Sierra? The tire does want to come off?
Dec 5, 2008 at 4:30 AM
  • 110,240 POSTS
Hi:
If you have the lug nuts removed and the tire is still tight, you will need to hammar it off from the rear of the tire. Corrosion sometimes causes the wheel to stick. If you can, use a dead blow hammar (rubber coated) and is less likely to damage the wheel.
Let me know if this helps.
Dec 11, 2008 at 6:54 AM
