1987 Oldsmobile Cutlass Voltage drops when air conditioning
RICHARDFRANK
Electrical problem
1987 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
The voltage drops when air conditioning is running. The altenator has been checked and seems to be ok. But when a lode is placed on the vehicle the voltage drops going to the battery. The car will not start after the battery has been drained.
Jul 25, 2010 at 8:18 AM
HMAC300
  • 48,601 POSTS
charge teh battery and then take it to see if it's any good or not. It may be to weak. Also check to see if there is a draw ont ehbattery when the car is shut off.
Jul 30, 2010 at 2:03 AM
DYLANROBERTS
  • 5 POSTS
It is most likely your voltage regulator and on that year it is part of the alternator the only way to fix it is to buy a new alternator a great way to make sure its your volt regulator turn on your car turn on your head light switch them to high beams then have a friend press on the gas as you watch the headlights if the regulator is bad the lights will dim and brighten
Dylan
Sep 10, 2010 at 10:34 AM
