1987 Oldsmobile Cutlass Power Steering Belt Tension
BSTELZER
Engine Mechanical problem
1987 Oldsmobile Cutlass V8 Two Wheel Drive Automatic
I have a loose power steering belt on my 1987 cutlass (307ci) and I have found all the bolts, but I still can't get the pump to slide over. There is no tension pulley on this model. Any help would be greatly appreciated.
May 9, 2009 at 9:25 AM
  • 110,248 POSTS
One of two things... Either you missed a bolt (could be in the back of the pump) or the belt is stretched to a point that there is no more room to move the pump.
May 27, 2009 at 3:45 AM
