1987 Oldsmobile Cutlass how distributor should react
1987 OLDSMOBILE CUTLASS
KRINGLE1965
Engine Performance problem
1987 Oldsmobile Cutlass V8 Two Wheel Drive Automatic
on a 403 engine with an hei distributor ,as the rpms increase the timing should advancein degrees? what is the correct place to route the distributor vaccum hose for an edlebrock carb. ? and as you advance timing should engine rpm increase or decease?
Jun 4, 2010 at 1:19 PM
Vacuum hose should be hook up above the throttle plate for ported vacuum and when you advance timing you increase the idle speed
Jun 4, 2010 at 2:23 PM
