1986 Oldsmobile Cutlass line from Radiator leaking
1986 OLDSMOBILE CUTLASS
76,000 MILES • 4 CYL • FWD • AUTOMATIC
KSEIGEL
On the left side (driver's) of the vehicle there are two lines, one in and one out of the radiator. They are steel lines with an 8 to 12 inch section of rubber hose. The bottom hose is leaking where it attaches to the steel line on the engine side. Is this a transmition cooling line and the fluid leaking would then be transmittion fluid, correct ?
Mar 8, 2010 at 6:57 AM
  • 110,244 POSTS
That sounds correct. Is the fluid that is leaking red in color?
Mar 10, 2010 at 1:27 AM
