Monday, May 5th, 2008 AT 4:05 PM
My fuel Gauge reads 1/4 tank when full. It will go down to E as the fuel empties from the tank. I have already changed the sender in the tank (lots a fun) and this did nothing to correct the probelm. I noticed that when I unplug the lead coming from the sender the gauge goes to full. With the lead from the sender attached I pulled the ground off and it stayed at 1/4 when full. I checked the lead with a multi meter in between and seem to be reading 6 volts. Any ideas as I really do not want to run out of fuel again on I 95.
