1985 Oldsmobile Cutlass replace radiator fan
172,000 MILES • 6 CYL • FWD • AUTOMATIC
RETIREDTROOPER
radiator fan does not run , how do I replace it? THANKS
Jul 5, 2008 at 6:07 AM
BLUDOGG79
  • 7 POSTS
Remove the four screws from the engine support on the left side and lift it out of the way. Remove the four screws for the radiator top support and remove the support. Unplug the fan motor (the plug is located underneath the motor and is easily reached from underneath the car). Remove the four screws from the fan assembly (they are located at the four corners of the asembly). Remove the fan assembly.
Oct 12, 2008 at 7:59 AM
