1985 Oldsmobile Cutlass dashboard
1985 OLDSMOBILE CUTLASS
JVEAL
Engine Mechanical problem
1985 Oldsmobile Cutlass V8 Two Wheel Drive Automatic
Is there anything in your dash that can cause your car not to fire up i took whole dash off and hasnt replaced it yet?
Nov 13, 2009 at 12:16 AM
JDL
  • 16,098 POSTS
welcome to the forum, need more info. Are you saying it cranks good but won't start, or it won't even crank?
Nov 13, 2009 at 5:18 AM
JVEAL
It turns over but its slow ive replaced disrtibutor starter and alternator and even most recently the tranny was 200 now 350 .
Nov 17, 2009 at 1:27 AM
JDL
  • 16,098 POSTS
I'd make sure the battery has a full charge, also, if the spark timing is off, the starter may be fighting compression?
Nov 17, 2009 at 1:53 AM
JVEAL
fully charged batttery how do you adjust spark timing
Nov 17, 2009 at 3:26 AM
JDL
  • 16,098 POSTS
You'll have to get a timing lite, are there timng marks and pointer on the harmonic balancer? I tried to post a picture, couldn't get it to work, will try later.
https://images.2carpros.com/forum/automotive_pictures/170934_olds_timing_spec_3.jpg
This is for 5.0 vin Y, automatic, 20 degrees btdc, @1100 rpms.
Nov 17, 2009 at 5:00 AM
