1984 Oldsmobile Cutlass replacing engine
LORDJOKER5
  • 7 POSTS
Engine Mechanical problem
1984 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
i have a olds 350 i want put in replace of a 231 buick v6. what has to be changed in the car with the v6 before i can put in the v8. does any parts from the 84 buick 231 v6 fit on the 79 olds 350 v8 at all just wonder. can i use my spark plugs from the v6 for the v8 because i have 6 new ones and 2 long old ones.
Feb 11, 2009 at 10:38 AM
  • 110,251 POSTS
Hi:
Nothing will cross over. Especially the plugs. As far as the engine, anything is possible, but everything needs changed and I recommend staying with a direct replacement.
Feb 19, 2009 at 6:41 AM
