I recently purchased this cutlass. Tha AC has not worked. I found the plug that connects to the compressor was unhooked. When I plugged it into the compressor I still get nothing. I am getting 12 volts to the green wire on the plug when the the thermostat & switch are on. How can I know if my issue is a compressor issue without purchasing a compressor. I also checked and the freon is full.
The plug to the compressor also has a diode from the hot side looping over to the ground side. Is this normal ? (I have never seen that before).
All help is appriciated.
Thanks[img:ebc9910357]http://www.2carpros.com/forum/automotive_pictures/386420_DSCF0290_1.jpg[/img:ebc9910357]
Jul 22, 2009 at 12:06 PM
