1977 Oldsmobile Cutlass Engine swap
1977 OLDSMOBILE CUTLASS
MA501207
Engine Mechanical problem
1977 Oldsmobile Cutlass V8 Two Wheel Drive Automatic
will a chevy 327 fit in a 77 oldsmobile cutlass and will a chevy s10 rear end fit in a 77 oldsmobile cutlass? And if not can it be modified to fit
Feb 18, 2009 at 1:22 PM
  • 110,240 POSTS
Hi:
One can make anything work if you have the time and money. The engine will fit, but there will need to be many changes.
As far as the differential, that I can't answer. I would say no.
Feb 19, 2009 at 2:45 AM
