1976 Oldsmobile Cutlass sending unite
1976 OLDSMOBILE CUTLASS
148,000 MILES • V8 • 2WD • AUTOMATIC
JSTRAND93
i have a problem with my sending unite because its stuck on full and i have tried some seafom in the gas tank to see if it was just stuck but it hasnt changed so i wondering how much work would be done to fix it.
Mar 9, 2010 at 3:12 AM
  • 110,244 POSTS
Are you refering to the fuel system?
Mar 10, 2010 at 12:57 AM
  • 110,244 POSTS
Hi:
First, thanks for the positive feedback. It's appreciated. Next, you need to remove the fuel tank to access the float sending unit. There is a simple rheostat that send the signal to the gauge. If it is bad, you will get a false readling.
Mar 11, 2010 at 2:35 PM
JSTRAND93
ok i will try to that. and do you know where i can find one and how much they usually go for.
Mar 12, 2010 at 2:36 AM
  • 110,244 POSTS
Call parts stores in the area for availability and price. I'm not sure what they would sell for anymore.
Mar 12, 2010 at 2:45 AM
JSTRAND93
ok, thanks for your time
Mar 12, 2010 at 7:23 AM
JSTRAND93
when i drive and put in reverse and turn sharp there is a loud clicking noise and i don't know what it is.
Mar 12, 2010 at 7:41 AM
  • 110,244 POSTS
Can ou tell aprox where it is coming from?
Mar 12, 2010 at 11:35 AM
