1970 Oldsmobile Cutlass Do I Have Blown head Gaskets?
1970 OLDSMOBILE CUTLASS
21,000 MILES • V8 • 2WD • AUTOMATIC
BXMAN
My 1970 Cutlass Supreme SX, Has a 365 HP, 455 CI Engine, 4 Barrel Carb. W/Dual Air Induction Hood, and Dual Exhaust.
The car from day 1 always had the hot light on, but never overheated, and when I brought this to the attention of my mechanic, he said that it was just an idiot light?
I bought this car 8 years ago, and for the last 3 years it was sitting outside parked in a driveway without being started. Finally, I had some work done in January to get the car going again.
I had all the fluids drained, hoses changed, tuned it up, and it ran like a top.
I did question if any of the gaskets throughout the vehicle would be affected by sitting a long time, and the mechanic said, you would have to wait and see.
4 weeks ago I went to take the car out for a spin, and as I was driving in the garage, I noticed smoke in front of my headlights.
When I checked it out, the radiator was leaking with engine oil mixed in with the anti-freeze. The engine was smoking and overheating, and the hot light was shining brighter than ever.
I only drove the car 4 stories back into my parking slot, and turned the engine off.
I told a mechanic about it, and he said he would do the head gaskets, but at the same time was reluctant, telling me he would charge me $1200.00 to fix, and if it failed, he didn't want to know from nothing since it was an old car engine.
This car has 21000 miles on a rebuilt original matching engine! I want to sell this car for a good price.
How much should it cost to do all the Head gaskets
What can I do? Please help me?
Thank You Tony.
Jul 23, 2008 at 3:51 PM
3yrs being park outside and it blew a headgasket while sitting. You sure its not transmission fluid from the cooler compartment of the radiator.
Get it block and pressure tested to ID a blown headgasket-cracked head or block-
Jul 23, 2008 at 4:18 PM
BXMAN
[quote:449d9d3938="rasmataz"]3yrs being park outside and it blew a headgasket while sitting. You sure its not transmission fluid from the cooler compartment of the radiator.
Get it block and pressure tested to ID a blown headgasket-cracked head or block-[/quote:449d9d3938]
The Headgasket did not blow just by being parked outside while sitting, but they may have dried out from not being used for 3 years? This happened 5 months after getting the car going again.
Jul 23, 2008 at 4:43 PM
Get it block and pressure tested to ID a blown headgasket-cracked head or block-this will give you an idea if it is. 3yrs will not dry out the headgasket. The gasket is made out of a special material that can withstand pressure/heat-
Jul 23, 2008 at 4:50 PM
BXMAN
[quote:e51e895a1d="rasmataz"]Get it block and pressure tested to ID a blown headgasket-cracked head or block-this will give you an idea if it is. 3yrs will not dry out the headgasket. The gasket is made out of a special material that can withstand pressure/heat-[/quote:e51e895a1d]
Thank You so much Rasmataz, I had already bought a new radiator in addition to whatever job needs to be done. Again many thanks, Tony.
Jul 23, 2008 at 5:02 PM
