I am replacing the heads on the Olds 350 and would like to know the torque specs for the heads and pattern?
Dec 7, 2009 at 3:02 PM
HMAC300
✓ASE Certified Mechanic
Torque spec is 80 ft lbs. there is no sequence other than to start with the center bolts, upper and lower and work your way outwards on both sides...
Dec 20, 2009 at 8:22 PM
