1969 Oldsmobile Cutlass HIGH OIL PRESSURE
1969 OLDSMOBILE CUTLASS
RICHARD MCBRIDE
Engine Mechanical problem
1969 Oldsmobile Cutlass V8 Two Wheel Drive Automatic
NEW REBUILT 350 OLDS MAYBE 20 MILES ON IT
REAR MAIN MAJOR LEAK
OIL PRESSURE IS 60 # AT IDLE AND 75# AT 2500
DID OIL PRESSURE CAUSE IT OR MAIN SEAL.
Oct 17, 2008 at 9:40 AM
Check the oil pump pressure relief valve it might not be opening or wrong undersize crankshaft bearings
Oct 17, 2008 at 10:05 AM
  • 55,428 POSTS
The main seal failed, high oil pressure probably did not cause it though.
Nov 10, 2008 at 4:55 AM
