2010 Oldsmobile Ciera drain hose
20,000 MILES • 6 CYL • FWD • AUTOMATIC
JCAC
I recently bought a 94 Oldsmobile ceria; the previous owner never ran the ac. I put 134a Freon in it and it leaked out within a few minutes along with that inside the passenger side of the car floor was soaking wet. Where is the drain hose and how can I stop the Freon from leaking out?
May 28, 2010 at 5:00 AM
  • 110,248 POSTS
The drain is under the hood on the passanger side firewall. As far as the leak, you have to locate where it is to determine what is causing it.
Jun 3, 2010 at 5:37 AM
