1997 Oldsmobile Ciera starting
104,000 MILES • 6 CYL • FWD • AUTOMATIC
ADAMPADO
My ciera has trouble starting. Usually I turn the ign once and no start. the second time it fires up. If I do it three times withouit starting or push the pedal too soon It seems like it is flooded (smells of gas). I then wait a couple meinutes and it starts on the second turn again. When the engine is warm it starts right away. Can you help?
Thank You Adam
Sep 14, 2009 at 3:39 AM
  • 110,248 POSTS
I need you to check fuel pressure and fuel pressure drop off. You may have a leak and it takes the pump a few seconds to reprime the system. Here is a how to video and directions:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Sep 16, 2009 at 5:48 AM
