1996 Oldsmobile Ciera Rear Window Defroster
71SUB4X4
Electrical problem
1996 Oldsmobile Ciera 6 cyl Front Wheel Drive Automatic
Defroster will not turn on. I suspect it's a relay problem.
Where is the relay?
Any other ideas why the defroster will not turn on?
Allen
Jan 25, 2010 at 5:23 AM
  • 110,248 POSTS
Hi:
The relay will be under the hood in the relay block. However, I would recommend checking to see if there is power to the switch first.
Apr 9, 2010 at 6:25 AM
