1996 Oldsmobile Ciera PROBLEM NOT LISTED
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
DYNODAVEDJ
The door will not close because the lock mechanism seems to be blocking it.
Jan 26, 2010 at 1:05 AM
SLUCEY
[quote:20928f3589="dynodavedj"]1996 Oldsmobile Ciera 6 cyl Two Wheel Drive Automatic 160000 miles
The door will not close because the lock mechanism seems to be blocking it.[/quote:20928f3589]
I am guessing that since it has been over 3 weeks since you've asked this, you figured the problem out, but, on the off chance you didn't I figured I'd lend a hand.
Open your car door and take a screwdriver, or other object, slide it under the mechanism, and pop it back in place. It probably looks like a D or an O before you do this, should look like a C when you are done.
Feb 18, 2010 at 2:48 PM
