1996 Oldsmobile Ciera how to change an oil pan on an 1986 o
200,000 MILES • 4 CYL • FWD • AUTOMATIC
WEAPONHEAD
  • 7 POSTS
ok... i have an 86 olds cutlass ceara 4cyl 2.5L 2 door... i have a crazy oil leak... i patched it a few times... keeps coming back. got a new oil pan to replace it but i cant get to the bolts holding the pan on... the trany is sitting ontop or under... however you wanna say it. how to i get the pan off... i REFUSE to let this car die because of this small prob.
your guys rule. thanks for the help!!!
Oct 10, 2009 at 1:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you must lift engine up in order to replace the oil pan gasket and / or oil pan ..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1065.jpg
Oct 10, 2009 at 1:37 PM
