1996 Oldsmobile Ciera Fuel gauge doesnt work
1996 OLDSMOBILE CIERA
CSJ1984
  • 8 POSTS
Engine Mechanical problem
1996 Oldsmobile Ciera 6 cyl Front Wheel Drive Automatic 138K miles
1996 ciera with 138k mi. Has been sitting for a couple of years, i recently started getting it back running. So far everything still works great except for the fuel gauge. when it was parked it didnt have much fuel in it and i have only put a couple gallons in it just to get it running. the needle is all the way past full and doesnt move at all. what could be the problem?
Sep 19, 2010 at 3:29 AM
KHLOW2008
  • 41,814 POSTS
Hi csj1984,
Thank you for the donation.
Possible causes are :
1. Bad fuel gauge.
2. Short between sending unit wire to gauge.
3. Faulty or stuck sending unit.
Unplug the sending unit wireharness and check if the gauge shows Empty when ignition switch is turned ON.
Sep 19, 2010 at 5:55 AM
CSJ1984
  • 8 POSTS
how do i test to see which one of those things it is? where is the plug to the harness for the sending unit? if it is stuck is there anyway to un-stick it or does it need to be replaced?
Sep 19, 2010 at 6:16 AM
KHLOW2008
  • 41,814 POSTS
The first test outlined would confirm if the gauge is faulty.
The harness connector is on top ot the fuel tank, connected to the fuel pump housing.
You would need to remove the sending unit to test if it is faulty. That would require the fuel tank to be dropped.
Sep 19, 2010 at 6:43 AM
CSJ1984
  • 8 POSTS
do i need to drop the tank to access the harness? if the gauge is faulty how would i go about fixing that?
Sep 19, 2010 at 6:55 AM
KHLOW2008
  • 41,814 POSTS
Under the seat there is a connector for the sending unit which can be used for testing purpose. I do not have the diagram for the exact location. Look out for a Purple wire with a Grey wire bunched together.
If the gauge is faulty, it would have to be replaced and might require the instrument cluster to be replaced as an assembly. The chances of the gauge being faulty would be lesser than the sending unit.
Sep 20, 2010 at 5:32 AM
CSJ1984
  • 8 POSTS
I drove the car up on ramps and changed the oil today. When I started it the needle on the fuel gauge moved from all the way past full to near a half of a tank. It doesn't have that much gas in it, do you think it was stuck and will correct itself when I fill it up? What do you think?
Sep 21, 2010 at 11:38 AM
KHLOW2008
  • 41,814 POSTS
Symptoms indicates a faulty sending unit rather than being stuck. The contact for the resistance coil in the sending unit seems to be intermittently losing contact and filling up might get it to work. however when the fuel level drop to the resistance part that is faulty, it might just go to Empty.
Sep 22, 2010 at 2:19 AM
