1996 Oldsmobile Ciera Engine Heating Problems - What could
101,580 MILES • 6 CYL • FWD • AUTOMATIC
ARTZDELUX
About a month ago I noticed erratic temp. gauge behavior. Once the car was on the road for a few minutes, the temp gauge goes from cold to 1/2 in about 5-10 seconds, then shoots back down to cold to 1/4 temp. I refilled my coolant and it went away for a few days. I've had to put in new coolant every 3-4 days for the last month but am noticing it is not having as much of an affect on controlling the temp. as it did.
Last few days I've noticed that the heater is taking longer to warm up and blow hot air (about 10 min) whether parked or driving. I have not noticed any smells or puddles of fluid/ liquid inside the car.
I am thinking this could be either the intake gasket (which I have read is a common issue with my make/ model), a heating core, or a head gasket.
Am I on the right track with the potential cause?
What steps could I take, if any, to diagnose better before I take it into a shop?
How urgent should I consider this issue?
Feb 1, 2010 at 1:41 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Coolant loss through intake is common if oil is not contaminated and no white smoke from exhaust then probably not head gaskets. The lack of heat and guage flux maybe the thermostat.
Hope this helps
Thanks for donate
Feb 1, 2010 at 4:30 AM
