1995 Oldsmobile Ciera is this the right port
1995 OLDSMOBILE CIERA
160,000 MILES • 6 CYL • FWD • AUTOMATIC
NICEGUY30
yeah i want to put some freon in my ciera, i was wondering if the port underneath the windshield is the right one, i have put freon in 2 cars ive owned before so ive done it before, ive used the stuff at walmart for my last cars
May 28, 2009 at 8:43 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:9ceffbc88b="niceguy30"]Air Conditioning problem
1995 Oldsmobile Ciera 6 cyl Front Wheel Drive Automatic 160000 miles
yeah i want to put some freon in my ciera, i was wondering if the port underneath the windshield is the right one, i have put freon in 2 cars ive owned before so ive done it before, ive used the stuff at walmart for my last cars[/quote:9ceffbc88b]
Hello
If you are using the singe hose to fill and it is r134a and you know the location of the 2 ports. Then the smaller of the ports is the low pressure side you will fill from. Also it will only fit the low pressure side. So, if you go to put it on and the port is to big then try the other port.
May 28, 2009 at 9:06 AM
